Hi all,
Each time I edit any layer or sublayer (rename, add, change attributes, etc, even if I did cancel the edit action), the whole root layer is extended without any respect for the previousely agencement of the tree's view.
Is there a quick hack to keep the tree's order like it was before after editing any layer ?
Thank you, Reno.
Debian 8.0 Jessie.
Qcad pro 4.14.3
The whole root layer list is fully extended as soon any
Re: The whole root layer list is fully extended as soon any
No, the tree is essentially regenerated from scratch everytime something in the layer list has changed. Layer folding states cannot be remembered or stored in DXF/DWG at this point although this might change in a future version.
There is an existing feature request for this at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1208
