Setting layer line widths to non-cyclic values
Postby clothbot » Wed Dec 09, 2009 10:29 pm
How do I set a given layer's line-width to something other than one of the cyclic options?
I need to be able to set layer line widths to 0.003mm and 0.03mm to generate SVG files for Ponoko laser cutting.
Thanks!
Andrew.
clothbot
Postby andrew » Fri Dec 11, 2009 12:00 pm
Line widths are limited to the ones in the drop down list of QCAD.
You might be able to post process the SVG files (XML) using XSL or sed or a simple search/replace in a text editor.
Postby clothbot » Thu Dec 17, 2009 7:22 pm
Thanks for confirming. I used the "sed" approach to post-process.
clothbot
