step by step process for importing a bitmap (ex. *.png file)
Postby akridge » Tue Mar 02, 2010 4:05 pm
Trying this again since the previous message didn't get answered.
I've done some searching and it appears I should be able to import a file of type PNG but I've been unsuccessful with getting it into QCAD. Need help with a step-by-step process for doing this.
Using QCAD version is 2.2.2.0 Professional, OS is Mac OSX version 10.5.8
Thank you,
Scott
akridge
answer
Postby akridge » Sat Mar 06, 2010 2:32 pm
I found out how to insert a gif or digital image.
Open QCAD and go to DRAW->INSERT IMAGE then choose the image from the file selection window.
akridge
Postby andrew » Sat Mar 06, 2010 2:35 pm
What exactly is the problem with PNGs? Can you not choose a PNG file in the file dialog? Can you insert it but it does not show? Does it show but not correctly? Please be as specific as possible, thanks.
clarification
Postby akridge » Sun Mar 07, 2010 5:50 am
I got it to work correctly, just posted the steps so others could use. I only tried GIF but I'm sure PNG would work fine also.
Scott
akridge
