CommandLine short cuts not working for me
Posted: Sun Jun 03, 2007 6:00 pm
by webrider
I have pro v2.1.3.2 and can't seem to get the two letter commands to work. For example, I can type <linerectangle> and hit enter and I am correctly prompted for the first corner location.
If I type <re> my command is ignored and the command prompt repeats itself.
Must be something simple I am doing wrong. Caps lock is off and I am using WinXP Pro SP2.
command line short cuts
Posted: Mon Jun 04, 2007 6:26 pm
by makeitsimple
Hi Webrider,
Sorry do not have the answer and I like you have the same problem
so am looking for someone to come up with the answer. Seventeen people have read your topic, are they all like us and don't know or can't be bothered to tell us ?? I posted the question on the parts library and over sixty people viewed before I posted the answer myself
Similar sitution do people not know these "simple" thing and want to learn or are people (me) not reading the literature. Does it need altering for people like me,makeitsimple applies to my projects and the way I need to have things explained !!!
Come on you guys out there lets help each other. Very sad when you have to answer your own questions and webrider is the only one out there asking them !!
Best Regards
Posted: Tue Jun 05, 2007 4:29 am
by rlhorn
It seems that there is a bug with the short cut commands. I tried <lr> for the command in question, and it works. so I tried a few more of the shortcuts, and most seem to not be working correctly.
I am using QCad Pro v2.1.3.2 on Ubuntu 7.04
Posted: Tue Jun 05, 2007 5:15 am
by webrider
Thanks for your help. I just tried <lr> and it works for me using v2.1.3.2 on winxp-pro sp2 OS. Most others don't work for me either.
I can live with new bugs, and understand that it may take time to find and fix. I just don't find it acceptable when our problem inquiries are ignored. Come on, QCAD developers, just respond and say it is a known problem instead of making us chase our tails out here in the dark.
It would also help if all posts included the operating system since this is a cross-platform program.
I find the program to be very powerful overall, and I can accept an ocassional issue. It is the none response that is most frustrating.
