Import DXF
Posted: Wed Jun 13, 2007 9:34 pm
by iw2nzm
Hello!
I'm using the demo version of QCAD and I'm going to buy the Pro version. I'd like to know if it can import AutoCAD dxf file. I tried with one but even if the layer list was complete, only few layers was visible.
Is there anything to do to open such a file?
thanks
Marco / iw2nzm
Posted: Fri Jun 15, 2007 10:04 pm
by fridge
Hi iw2nzm,
I had/have the same problems. As far as I can oversee it is no problem to import Autocad dxf-files, as long as they are the older versions, so no go for Autocad 2004/2007. I use a lot of external references and that is also a no go regarding importing. But standard drawings with nothing fancy in it are working fine.
Greetings,
Fridge
Posted: Sun Jun 17, 2007 7:30 pm
by iw2nzm
fridge wrote:Hi iw2nzm,
Greetings,
Fridge
Fridge,
thanks for your answer. I'll try to open an older Autocad dxf file. Are there any plug-ins to import current Autocad dxf files?
Bye,
Marco / iw2nzm
Posted: Sun Jun 17, 2007 9:13 pm
by fridge
Hi Marco,
I'm sorry but I can't help you regarding importing newer versions of AutoCad-dxf files into QCad. I just use AutoCad and save the file in an older version. I really don't know if there are plug-ins or other tools to do this without using AutoCad.
With regards,
Fridge
Posted: Mon Jun 18, 2007 7:54 pm
by iw2nzm
Ok, thanks!
Marco / iw2nzm
dfx from autoCAd
Posted: Tue Apr 15, 2008 11:27 pm
by SFC
I find that it works fine if from the autocad program you do a save as and save it as a DFX 2004 format or older (dfx 2002 etc.). DFX format generally does not support xrefs, paper space and other advanced autocad stuff.
