Object properties limited to two decimals?
Posted: Tue Feb 08, 2011 6:42 pm
by dugernaut
I need to change a circle radius to three or four digits of precision, but the properties only allow 2 digits of precision. How can I do this?
Doug
Posted: Tue Feb 08, 2011 8:45 pm
by Ferdi
o Modify -> Properties (or type pr)
o Select the circle
o Radius: [ xx.xxxxxxx ]
Ferdi
Posted: Tue Feb 08, 2011 9:15 pm
by dugernaut
Thanks!
I would have expected to be able to do that through the Property Editor window.
Let me ask for this as an enhancement.
Posted: Wed Feb 09, 2011 9:00 am
dugernaut: That will indeed be improved for QCAD 3 to six decimal places.
Posted: Wed Mar 16, 2011 9:23 am
by faber
dugernaut wrote:Thanks!
this is an aspect that I fully share.
the property editor window makes you believe that it is the only right place where you can change the object!(property, attribute)
but I am learning these days that this window is quite useless.
