I'm running QCad 2.1.3.2 on a Solaris 10/x86 machine. My printing is through CUPS with lpr/lpd. How do I specify the printer to use to QCad? I'd edit the qcad.ini file, but I don't know the semantics.
When I select File->Print there is no printer listed. I could export to pdf, but I'd prefer to print directly.
I also tried PDF Export to the file "| lp -d EpsonC82" but that just gives me a file named exactly that.
TIA,
Donald.
