change text position in angular dimensioning
froebe
Postby froebe » Fri Jan 04, 2008 11:01 am
Hi, I would like to change the text position in angular dimensioning. With linear dimensioning it works fine . Any suggestions ?!
Dirk
jonboy
Angular Dimensioning
Postby jonboy » Tue Feb 19, 2008 11:36 pm
Hi, to change the text position of angular dimensions, I have found that having inserted the angle dimension, select it and explode it (xp), you can the reselect the text and reposition it as required.
froebe
Postby froebe » Fri Mar 07, 2008 9:49 am
...works fine, thanks !
ttrw
Postby ttrw » Fri Mar 07, 2008 12:29 pm
Dirk, it is also possible to move it by just clicking, then dragging on the text, where it highlights with a blue square. This way, there is no need to explode the text.
