okay, I tried jonboy steps and I just create lines. I also check the freeform to make sure nothing snaps anywhere else.
I do keep an eye on the command line and did follow that, but I'm I missing something else?
So does qcad only makes extension lines as a dimension and the label is supposed to be the dimension? I'm asking because I thought the label was just that, a label or is this where the actual dimension number is supposed to go? Sorry, but I'm just confused as heck with this. Where do I type the dimension number and will the drawing redraw for this dimension? I haven't changed any default directory settings so I am running it from were it's installed.
Let me see if I can add a screenshot for you...guess not
[/img]
