gigantic property page when doing dimensioning
Postby froebe » Fri Mar 07, 2008 9:42 am
Hi folks,
how do I get rid of the gigantic property page on the left side of the screen when doing dimensioning. There is almost no more space to work on the right...
froebe
Postby ttrw » Mon Mar 17, 2008 11:25 am
Hi.
Not too sure what you mean. Can you be a little more specific? For eg, send in a screenshot?
I for one, don't get this problem you describe. You may be doing something wrong.
Tom
ttrw
Postby andrew » Mon Mar 17, 2008 1:41 pm
froebe: you might have accidentally moved around some toolbars / widgets and changed the layout in a way you didn't intend to. You can reset QCad by deleting its configuration file:
Unix / Mac OS X: ~/.config/RibbonSoft/QCad.ini
Windows: "C:\Documents and Settings\username\Application Data\RibbonSoft\QCad.ini"
Postby froebe » Mon Mar 17, 2008 4:16 pm
Many thanks !
I deleted to Qcad.ini file and started up with a new one.
Result: All fine !!
froebe
