Position of labels on dimensions
Postby michaelsr » Fri May 16, 2008 10:56 am
Hi - Is there a way to position the dimension labels so that they do not overwrite the dimension line? There does not appear to be any kind of offset.
Thanks,
Michael
michaelsr
Postby andrew » Mon May 19, 2008 12:44 am
You can set up dimension parameters in the drawing preferences (edit menu). You may also want to move the dimension labels in certain situations:
1. select dimension
2. drag and drop blue spot at label position
Postby michaelsr » Thu May 22, 2008 10:46 am
Thanks, problem solved. I really must open my eyes next time! Completely missed the additional blue dot.
michaelsr
