Measuring Arc Angles
Posted: Tue Apr 24, 2007 11:13 am
How do I measure the angle between an arc and an intersecting line? I know the angle will be constantly changing depending on where abouts I am measuring on the arc but is it possible?
Also is it possible to put onto my drawing the total length of an entity. In the measure tools I used the command and it worked fine but just shows the total length in the console. Is there a similar tool in the dimension menu?
I wanted to put on my drawing the circumference of an arc I have drawn. At the moment I have just had to copy the measurement from the console and put the text on the drawing manually.
