Getting XY coordinates of some blocks
Postby AntonioVR » Fri Sep 19, 2008 4:13 pm
I have a dxf file with some layers, and in one of these layers there are several blocks. I need to extract the coordinates of the points which define each block. Is there any way to obtain that? It would be valid even a command giving the list of the points, so that I can copy and paste it...
I have never used any CAD program, so I do not have too much idea (if you could explain the procedure in a easy way).
Thank you in advance!!
AntonioVR
Postby andrew » Fri Sep 19, 2008 7:58 pm
You can click on a block insert to select it and then look up the insertion coordinate in the property editor. I don't see a way to automatically stream all positions into a text file or something like that.
If you are comfortable with editing and digging plain text files, you can extract the positions directly from the DXF file.
