Drawing Images
Drawing Images
Postby makeitsimple » Wed Oct 08, 2008 12:05 pm
Hi all, I find Qcad easy to use and an excellent product, but am having problems inserting images. I am ending up with just a border with nothing in it. Doing somehing stupid but cannot solve it.
Any ideas out there please?
makeitsimple
Postby andrew » Wed Oct 08, 2008 12:43 pm
Most likely you are in draft mode.
See also:
http://www.ribbonsoft.com/qcad_doc_faq.html#12
-> 12. I can't see any hatches / large texts / bitmap images.
Drawing Images
Postby makeitsimple » Wed Oct 08, 2008 1:34 pm
Yes draft mode !! What a prompt reply :D
makeitsimple
Postby theblitz » Mon Oct 27, 2008 2:52 pm
Switching back and forth between draft mode made no difference and my settings are as shown (though mine are cm based).
I am probably just using the wrong command.
I am using the "dimaligned" command.
What I get is a line parallel to the original line with connection to the corners.
Looks like this (blue line is the dimensions layer):
theblitz
Postby andrew » Mon Oct 27, 2008 2:55 pm
Your dimension labels are too small.
Please refer to my answer to your original post:
http://www.ribbonsoft.com/rsforum/viewtopic.php?t=567
