create polyline from segments not working?
Postby silaste » Fri Nov 14, 2008 10:01 am
I can't get the create-polyline-from-segments tool to work even on a simple drawing with nothing else than lines that share one endpoint on a layer that is not locked. Am I doing something wrong or is this a bug? Should this also work with splines?
regards: Seppo Silaste
silaste
Postby andrew » Mon Nov 17, 2008 9:34 am
Please note that there is no visual feedback for this tool. You can proceed like follows to check if the tool was successful:
1. Start tool to convert segments into a polyline.
2. Click any one of the segments.
3. Terminate tool (right click)
4. Click one of the segments. The whole polyline should now be selected and treated as one entity.
This tool does not work directly with splines. You need to explode the spline first and then convert the exploded segments into a polyline.
Postby silaste » Mon Nov 17, 2008 2:47 pm
Ok. But it seems that you can't create a polyline from a polyline and a segment. The polyline has to be exploded first. But you can then select all segments and combine them into a polyline with one click. Visual feedback would be nice though.
silaste
