"blow up" a section of a drawing for printing
Posted: Sun Feb 15, 2009 8:20 pm
by SkyWatch
Given a building drawing with several rooms, how can I "blow up" one room so that I can PRINT JUST that one room WITHOUT having to copy its entire structure to another window/drawing, or go through a tedious procedure of selecting that room's elements and hiding everything else in the drawing?
If I zoom in to that one room, the print preview still shows the entire drawing.
Re: "blow up" a section of a drawing for printing
Posted: Mon Feb 16, 2009 9:53 am
You will have to adjust the scale factor in the print preview until the part you want to print fits on the paper. See also QCAD manual -> printing.
Posted: Tue Feb 17, 2009 1:29 am
by SkyWatch
Hmm - OK. Good answer, though the Manual does not make it intuitively obvious that using the PAPER icon as a SELECTION FILTER is how to control what will get printed, and thereby allow you to "zoom in" to a particular part of the diagram.
I tried what you suggested and it works. Thanks.
