Cannot edit text size in dimensions
Postby Steve » Tue Jul 28, 2009 4:51 pm
Just purchased Professional 2.2.2.0 and cannot seem to edit text in dimensions.
Found this answer on the Forum but my editor does not seem to have this selection. Any help welcome thanks.
"Yes, the property editor is available in QCAD Professional only. Please note that there is a separate forum for the QCAD community edition."
Regards
Steve
Steve
Postby andrew » Tue Jul 28, 2009 7:06 pm
Note that editing the dimension text size is different from editing the dimension text itself.
Dimension text size:
- Edit - Drawing Preferences - Dimensions
Dimension text:
- View - Toolbars - Property Editor (shows the property editor as a widget at the right)
- Select dimension entity(ies)
- Use property editor to change the label property (use "<>" for the measured length of the dimension entity)
Alternatively, you can also set the dimension text while drawing a dimension entity, see manual for details: http://www.ribbonsoft.com/qcad/manual_r ... ter24.html
The QCAD book also describes dimensions in detail: http://www.ribbonsoft.com/qcad_book.html
