Can I Place a Hole in a Hatch Area
Postby pestocat » Wed Jul 29, 2009 12:46 am
I have a rectangular hatch area and it also has circles inside where I need to have no hatch pattern. Is there a way to do this. The hatch area fills the circle area too.
pestocat
Postby Lorenzo » Wed Jul 29, 2009 9:04 am
The manual explains how to do that:
http://www.qcad.org/qcad/manual_referen ... ter25.html
1.activate hatch tool
2.select all the lines: external profile and internal islands that do not need hatch.
3.select the properties for the hatch and click OK.
Lorenzo
Postby J-J » Wed Jul 29, 2009 9:13 am
Select every entity, rectangle and circles, click the hatch tool, OK
that should do what you want.[/u]
J-J
Postby pestocat » Wed Jul 29, 2009 7:07 pm
J-J wrote:Hello,
Thank you J-J,
Your advice worked just as you said. This was the first time I used the hatch tool. Thank you very much.
pestocat
