- Code: Select all
999
this is a comment
999
this is another comment
If I open a file with VIM I can edit it, and put in my comments, but if I then use QCAD to open the file, and then save it, (regardless of whether I have made any changes!) my comments are removed from the saved file
How can I make a PERSISTENT comment in a .dxf file?
Ideally I would like the comments to last through having the file saved under another name, but even if they only stay in the file when it is saved under it's own name, that would be better than nothing...
I do notice that the lines
- Code: Select all
1:999
2-dxflib 2.2.0.0
Thanks,
Gooserider
