Making PERSISTENT Comments in .DXF files?
Postby Gooserider » Sun Aug 23, 2009 2:36 am
I am wanting to put some comments in some .DXF files that I am creating with QCAD pro-edition. I have found in the AutoDesk documentation that one can put comments in the file using the following structure
this is a comment
999
this is another comment
If I open a file with VIM I can edit it, and put in my comments, but if I then use QCAD to open the file, and then save it, (regardless of whether I have made any changes!) my comments are removed from the saved file :!: :x
How can I make a PERSISTENT comment in a .dxf file?
Ideally I would like the comments to last through having the file saved under another name, but even if they only stay in the file when it is saved under it's own name, that would be better than nothing...
I do notice that the lines
2-dxflib 2.2.0.0
DO seem to show up in the saved file every time, even if deleted in the original...
Thanks,
Gooserider
Gooserider
Postby andrew » Sun Aug 23, 2009 10:49 am
QCAD does indeed not retain any comments in a DXF file.
See: http://www.ribbonsoft.com/rsforum/viewt ... =2661#2661
