[Solved] Int between ellipse and circle
Postby Valdas » Tue Sep 08, 2009 10:20 pm
how to snap to intersection between ellipse and circle/arc? I tried "Snap -> Intersection" (QCad not want to place snap marker on intersection) and "Snap -> Intersection Manually" (when I select ellipse Qcad not shows snap marker on intersection when I place mouse near circle) but no success :(
This snap not work for me in QCad 2.2.2.0 Demo and QCad 2.0.5.0 Community Edition.
OS: KUbuntu 9.04 i386
P.S. sorry for bad English
Valdas
Postby andrew » Wed Sep 09, 2009 7:42 pm
This is currently not possible.
However, you can explode the ellipse which will turn it into an approximated polyline. After that, snap to intersection should work just fine:
- select ellipse
- modify - explode
Postby Valdas » Wed Sep 09, 2009 8:35 pm
Thanks, this trick worked.
Valdas
