divide a circle
divide a circle
Postby flow » Thu Sep 24, 2009 9:13 pm
I´m from Spain. Sorry for my english. How can I do?: divide a circle in five, six or seven equals parts (portions) Thanks.
flow
Postby andrew » Thu Sep 24, 2009 9:22 pm
- Draw a line from the center of the circle to the right
- Rotate line by 360/x degrees, x-1 times
- Use intersection points as dividing points
or
- Draw arc with and angle of 360/x degrees
- Rotate arc around its center x-1 times
Thanks, gracias
Postby flow » Fri Sep 25, 2009 2:00 pm
Thank you very much, Andrew. Muchas gracias, Andrew
flow
cron
