Exporting Drawing only by screen shot?
Riesen
Postby Riesen » Wed Nov 18, 2009 4:35 pm
I am very annoyed since the only way that works for me is a screen shot.
Version: 2.2.2.0
Settings:
Unit: Microns
line width 0.5mm
Paper format A4
width of drawing 10000µm
PDF-Export:
- QCAD crashes
print to file:
- 0 byte file
svg + bmp give hardly visible lines and very large images (resolution=1)
When I print the drawing everythis is fine.
Please fix this bug
FRK
Postby FRK » Thu Dec 03, 2009 5:52 am
Hello Riesen,
I tried duplicating your scenario and the PDF generated correctly.
Ver: 2.2.2.0
OS: Ubuntu 8.04
Paper Format: A4 Letter
Unit: Microns
Line Width: 0.5mm
Rectangle drawn: 10,000 x 7,000 um.
Not sure what you meant by "width of drawing 10000µm".
- FRK
