QCAD crashes at save operation under XP prof
Postby Heiko » Mon Jan 04, 2010 2:08 pm
Hi there,
I use QCAD 2.2.2.0 for about a year now. Until now there was no problem, but now I cant save anymore. QCAD crashes completely. I deinstalled it and installed it again. No change. My OS ist WinXP prof SP3.
Can you help me?
Heiko
Postby andrew » Mon Jan 04, 2010 2:14 pm
Please try to reset it by deleting the QCAD.ini file:
http://www.ribbonsoft.com/qcad_doc_faq.html#6
didnt work sorry
Postby Heiko » Wed Jan 13, 2010 9:34 am
Hi Andrew,
zhank you for that fast reply. Mine was not that fast.
i tried to delete the ini file and restartedQCAD. So I had to set language and units. I tried to oben a file, but it crashed again without any window opening.
Sorry
Have you another hint for me?
best regards :roll:
Heiko
Postby andrew » Wed Jan 13, 2010 7:53 pm
Heiko: Please update to QCAD 2.2.2.1 for Windows, which fixes problems with the file dialog on some Windows installations:
https://www.ribbonsoft.com/store
-> My Account
-> Login
-> View appropriate order
-> Click "download" button beside appropriate product
-> Download QCAD Professional version 2.2.2.1 (note that version 2.2.2.0 is also still listed, make sure that you download the newer version 2.2.2.1)
