Clean up after rework on drawings. SOLVED
Posted: Tue Jan 26, 2010 9:24 pm
I tried search with no luck. So here goes my question.
I am working mostly on floor plans right now. I make a complete plan and then 'save as' and rename the design. Now I will rework and area, say master bath for example. So I remove what is there and rearrange the area. I keep repeating the 'save as' and rework into a 3rd design. As I progress with these redesigns I find that some points remain and also show on the prints. I go back in with the edit tools but can't seem to get these leftover points to go away.
In the cleanup effort I zoom in much closer but still can not make a contact and removal.
Is there any sort of cleanup routine that I have missed in the book or the help section? If not, could such a thing be developed? Something that could be activated that would scan the drawing and eliminate any points not connected for example. These points are on different layers as I can hide the layer and make the spots go away.
