Numbers don't show on Command Line
Postby binto100 » Mon Feb 22, 2010 11:17 pm
I posted this in the How To section w/o results so I'll try here.
Numbers I enter on the Command Line do not show up once the command is executed.
For example I enter @0,0 in the Command Line for the start of a two point line and press enter. The line starts correctly at the relative reference but @0,0 does not show in the Command Line history. Then I enter the end point via the Comman Line and again those numbers do not apprear in the Command Line history.
Any help would be appreicated. Thanks.
Bruce
Win7, Qcad 2.2
binto100
cron
