Qcad 2.2.2.0 Professional on Ubuntu 8.0.4.
I have a (rather complex) drawing with a lot of layers. In an attempt to bring order to chaos, I created blocks (select items, create block, enter reference point, enter name). Then, because I forgot to select the correct layer in advance, change their layer to "drawing" with the property editor. So far, so good.
After a save and reload of the drawing, the fills in one of the blocks are suddenly missing for no apparent reason. Maybe the fill layer was off while saving, I can't rember (but that should not have mattered, right?).
When I want to edit that block to add the fills again, I am stumped to see that some entities seem to reside on the combination of layers "0" and "fill outlines": when either layer is turned off, the entities (which, according to the Property Editor, reside on layer "fill outlines") do not show. This behaviour is completly new to me...
The worst thing: this happens quite frequently, in defferent drawings. And in full compliance with Murphy's Law, the deadline is this afternoon...
Can anyone please explain to me what is going on here?
