QCAD Prof V2.2.2.0, WindowsXP. Library Browser insert proble
Postby ClaudeQC » Sun Mar 07, 2010 7:05 pm
- I use QCAD Professional V2.2.2.0 on Windows XP Professional SP3.
- I want to report the following problem...
- When inserting a block (drawing) using the Library Browser, the layer
properties (Color, Width, Line type) of the inserted block are temporarily
override by the layer properties of the layer in which the block is inserted.
To get the inserted block layer properties restored, I have to do a dummy
"Modify->Properties" on the inserted block, or close and open the drawing.
Claude Sylvain
Electro-Technica inc.
ClaudeQC
Re: QCAD Prof V2.2.2.0, WindowsXP. Library Browser insert pr
Postby LeoP » Mon Mar 08, 2010 11:03 pm
ClaudeQC wrote:....
When inserting a block (drawing) using the Library Browser, the layer properties (Color, Width, Line type) of the inserted block are temporarily override by the layer properties of the layer in which the block is inserted.
To get the inserted block layer properties restored, I have to do a dummy "Modify->Properties" on the inserted block, or close and open the drawing.
I observed the same thing, but not only with blocks from the library: it also happens with new instantiations of blocks already in the drawing. Any operation on the incorrectly shown block (e.g. move @0,0) will correct the display.
Happens under both Win2k and Ubuntu 7.0.4...
LeoP
