Selecting help from the menu or pressing F1 makes QCAD quit.
I just installed QCAD 2.1.3.2 on an up-to-date Ubuntu 7.04 as follows:
cd /opt
sudo tar xzvf ~/qcad-2.1.3.2-1-prof.linux.x86.tar.gz
sudo rm -r qcad-2.1.2.8-1-prof.linux.x86
sudo rm -r qcad-2.1.3.0-1-prof.linux.x86
cd /usr/bin
sudo ln -s /opt/qcad-2.1.3.2-1-prof.linux.x86/qcad qcad
If started by directly referencing the path rather than the link, I get the following error in the help window:
The page could not be found
'/opt/qcad-2.1.2.8-1-prof.linux.x86/doc/index.html'
I linked the qcad-2.1.3.2-1-prof.linux.x86 directory to qcad-2.1.2.8-1-prof.linux.x86 in /opt and by starting QCAD with the full path reference, now help works.
Is there a way to clean this up? Have I done something wrong in the install?
Alex
