line width scaling when printing
Postby hungerburg » Fri Sep 03, 2010 7:29 pm
in printouts qCAD does not scale line widths with the drawing:
eg. I draw a two by two meters box with 2mm line width.
- when printing with a scale of say 1:10, the strokes in the printout are still 2mm.
- when printing to pdf 1:1 and printing the pdf fit to say A4 paper, strokes are much thinner.
Is there some common understanding between dxf processing applications how to handle stroke width in scaled printing?
peter
hungerburg
Postby andrew » Mon Sep 06, 2010 9:36 pm
This behavior originates from traditional drafting. Pen widths are standardized to a few fixed pen widths. The pen width should not indicate the size or width of a real world object in CAD but rather the role of a line in a drawing (a 0.25mm wide line might indicate a visible edge, a 0.13mm line might be a part of a dimension entity or a hidden edge, etc.). Scaling line widths would work against these standards.
Note that you should always be aware at what scale / on what paper size the drawing will be printed before you start with a drawing. Line width standards often depend on paper sizes but not in a straight forward way that could be achieved with a simple line width scale factor.
I see
Postby hungerburg » Thu Sep 09, 2010 2:07 pm
I see, this sound awfully reasonable :) Thank You Andrew.
hungerburg
