Arcs X coords mirrored in block [2.2.2.0]
Postby HappyCactus » Fri Oct 22, 2010 5:32 pm
I have found a strange problem with QCad 2.2.2.0 under MacOSX snow leopard (10.6)
I have found a file that have many blocks. All seems ok except that the arcs seems to have the X coordinate mirrored.
I upload an image. The file can be downloaded here:
http://www.elbag.net/it/_dxf/MR6HD.dxf
This is the result I have. Note that the block is selected and displayed in brown. The arcs should be on the left side, with the others lines.
A pdf I can download from this site tells me that it should be ok from other viewers, but I can't be sure - may be the dxf is broken.
Someone other have the same problem? is this a bug or is the dxf broken?
Thank you in advance.
best regards
ing. Federico Fuga
HappyCactus
Postby andrew » Fri Oct 22, 2010 5:35 pm
Most likely an unsupported parameter in the DXF file (e.g. non-standard extrusion direction).
Postby HappyCactus » Fri Oct 22, 2010 5:37 pm
Hi Andrew,
thank you for your response.
Is there any way we can solve this issue?
Thank you, regards
Federico
HappyCactus
Postby andrew » Sat Oct 23, 2010 8:44 am
You would have to make sure that the original drawing does not use non-default extrusion directions.
Postby HappyCactus » Sat Oct 23, 2010 9:21 am
I can't. But I have solved - for now - by editing the blocks.
Is there a way to make a bug report?
HappyCactus
