If I add a door_01 - and then delete DIM (I did this because I didn't know what is was for) - nothing is removed on the drawing.
later, when I moved the door object to another layer - the dimensions on the door was gone - probably what the layer named DIM was - but I didn't notice it - since the dimension lines didn't hide, when I selected hide on the DIM layer.
Using 2.2.2.0
