Problem with german "umlauts"
Posted: Fri Apr 06, 2007 12:39 pm
by nepomux
Hi there,
when using QCad 2.1.2.8, I cannot read or create fie- or directorynames containing german umlauts.
In previous versions I also could not use umlauts in names of layers or in textboxes, but this works now.
It does not matter, which coding I use on my system, utf-8 or iso 8859-15.
System is debian sid (sidux).
Any suggestion?
Thanks in advance, Claus
Re: Problem with german "umlauts"
Posted: Thu Apr 12, 2007 8:20 pm
I'll have to pass this one on to TrollTech, maker of Qt. They scheduled a fix for the upcoming Qt 4.3 version, but I would not bet on that. At least the latest Qt 4.3 beta release still cannot handle umlauts in directory or file names.
nepomux wrote:Hi there,
Any suggestion?
Posted: Wed Aug 22, 2007 8:46 am
by nepomux
andrew wrote:I'll have to pass this one on to TrollTech, maker of Qt. They scheduled a fix for the upcoming Qt 4.3 version, but I would not bet on that. At least the latest Qt 4.3 beta release still cannot handle umlauts in directory or file names.
Hi Andrew,
I just compiled a new Version of qtpsfgui (
http://qtpfsgui.sourceforge.net) using Qt 4.3.1.
With this one I can access files and directories german umlauts.
Will there be a Version of QCad Professional compiled with a newer Qt-Version?
Grettings, Claus
Posted: Wed Aug 22, 2007 9:36 am
Sure. The next release will be compiled with Qt 4.3.x.
Posted: Wed Aug 22, 2007 11:34 am
by nepomux
andrew wrote:Sure. The next release will be compiled with Qt 4.3.x.
A hint, about when this will be?
Greetings, Claus
