Help file problem
Posted: Fri Sep 14, 2007 3:28 pm
Hi there,
I am using QCAD 2.1.3.2 under Windows2000. After the demo version I installed the full version.
The demo version was installed in Directory E:\Programme\QCAD Demo\ the new version in E:\Programme\QCAD\.
If I press F1 (for help) I get the Message:
The page could not be found
'E:/Programme/QCad Demo/doc/chapter14.html'
If I go to the Qt assistent settings, there is the right path : E:/Programme/Qcad/doc/index.html
but it will be ignored, however I tried to change it.
So for a solution, I installed a directory E:/Programme/QCad Demo/doc/ put in the help files and now it works.
But that is not how it should work.
Somebody any idea?
PS: That is the programm I was looking for a long time. Just what I need to do some 2D cutting.
Great work !
Somebody any idea?
Great work !
