I´m new to QCad and to this forum.
I´m not very familiar with CAD but use the program only for minor changes on some drawings.
Problem:
I have one drawing which is scaled 1:2
For example there is one dimension 10mm.
If I open the DXF-file using a viewer like eDrawings the dimension is correct shown as 10mm.
If I open the file using QCad the dimension changes to 5mm and so do all other dimensions.
If I say the dimension changes I mean the "written" number on the drawing changes from 10 to 5. And so if I print the drawing the part is half the size it should be...
Is it a bug or a feature?
Thanks a lot in advance for all your help
