QCad qcad-2.1.3.0-1-prof.linux.x86 Coring
Postby mikeperik » Wed Apr 18, 2007 12:51 am
I'm running QCad version qcad-2.1.3.0-1-prof.linux.x86 on a gentoo linux box. It is crashing regularly.
Tends to happen when I'm selecting things. I've got it generating core files but since it's built without debug info the trace back is not very informative.
What versions of libraries should I be using?
Mike
mikeperik
Postby michael » Sun Sep 16, 2007 11:04 pm
Use "ldd" command.
dynamic library path
etc. to track down the problem.
$LDD_LIBRARY_PATH I think this was it on Linux.
Maybe a script can set the path to the right libs.
michael
