Too many files open
Too many files open
Postby stewpye » Sat Jul 19, 2008 9:20 pm
Sorry in advance, this is hard to describe.
I find that I end up having many files open with the same name, but some don't have the latest drawing modifications.
I often have different files open and switch back and forth between them. The problem is if I have a file called file1, I will regularly save this file. Later when I'm closing windows I'll close file1 and other files but then earlier versions of file1 appear and I start freaking out thinking that I've lost the last 2 hours work!
Why is this happening, and is there a way of preventing it?
Cheers,
Stew.
stewpye
Postby andrew » Sat Jul 19, 2008 9:36 pm
Please make sure that you don't load the same file twice. You can see a list of all files that are currently open in the 'Windows' menu. If a drawing is listed there, simply click on it to bring it into view. If a file is not listed there, it is not open at the moment.
Postby stewpye » Sat Jul 19, 2008 9:44 pm
Ahh, ok. Thanks.
I've been looking at the list in the file menu. I'll keep an eye on the windows menu to see what I have open. I think that will solve my problem.
Cheers,
Stew.
stewpye
cron
