Space doesn't activate the command line
Posted: Tue Jul 29, 2008 10:52 am
I recently changed from QCad 2.1 to 2.2 and found out that I cannot activate the command line for text input by pressing space anymore, I have to move the cursor there by mouse and click in order to be able to input commands. Is this a bug or a feature? It is quite annoying when doing some repetitive actions requiring mouse and command line after each others.
Another odd thing is that while using the same line type and thickness selection the dashed line is scaled to approximately ten times longer dashes, than in the same drawing previously made with QCad 2.1.
