exporting problems
exporting problems
Postby markclews » Tue Jul 29, 2008 4:46 pm
hi
I'm trying to export Qcad's dxf files to pdf but they keep on hanging the application. Sometimes the application crashes. When I try to open the pdf's they are blank and their size is about 96 MB. They should be about 40 KB for the drawings I've been exporting. It was working earlier, but not at all now. I've not changed anything else on my computer. I'm running Qcad version 2.2.1.0 on Ubuntu 8.04. Can you help?
markclews
Postby juha_mustonen » Thu Jul 31, 2008 11:41 am
Sorry, can't help you, but I have noticed the problem with only custom page sizes (see http://www.qcad.org/rsforum/viewtopic.php?t=472). If you can modify the drawing to use standard page size the PDF export should work.
juha_mustonen
Postby andrew » Fri Aug 01, 2008 7:05 pm
Custom paper sizes will be fully supported in the next QCad release.
cron
