Dimension labels missing and help crashes program
Postby barjac » Wed Aug 20, 2008 8:59 pm
I recently tried to use the free Linux version on Mandriva Spring 2008.1
but after several hours struggling I realized that it was just so buggy that it was unusable.
I then downloaded the Pro demo with the intention of purchasing a license (after uninstalling the other version) and it performs better, but in a simple test it fails to display the dimensions against the dimension lines in both normal and print preview.
Also the help system shuts the program instantly.
AMD 64 running 32bit Linux Mandriva 2008.1 with 1Mb ram, nVidia FX5600 Ultra with nvidia driver.
barjac
Re: Dimension labels missing and help crashes program
Postby andrew » Thu Aug 21, 2008 8:07 am
barjac wrote:it fails to display the dimensions against the dimension lines in both normal and print preview.
FAQ:
http://www.ribbonsoft.com/qcad_doc_faq.html#13
-> 13. I can create dimensions but they show no label.
Postby barjac » Thu Aug 21, 2008 12:38 pm
A link directly to the FAQ in the software help menu would be good - especially the demo.
I am new to Linux, so a more detailed installation procedure in the help would have been useful or even a README in the package.
I will try the free version again - maybe a similar problem.
barjac
