PDF export some letters get grey
Postby nordlicht » Wed Dec 17, 2008 4:39 pm
QCAD: 2.2.2.0
Gentoo linux x86 all stable
Hi
I have a problem with the PDF export.
Letters in the drawing which only contain straight lines like E F H are correct.
Letters with diagonal lines or rounded lines like B G R get light grey in the pdf and the printout.
Is there a way to fix this?
chris
nordlicht
Postby andrew » Wed Dec 17, 2008 4:54 pm
This has most likely something to do with the anti-aliasing of your PDF viewer. You can probably switch that off in the preferences of the viewer.
Is there any such difference in the printed output?
