Possible bug when using blocks
Postby Drafter » Tue Mar 10, 2009 1:03 pm
When I place a block in a layer that uses line color red the block originally comes in as red but when I move the block or scale it it automatically changes to it's original color which is black lines. Am I doing something wrong?
I'm using version 2.2.2 on Ubuntu 8.04.
Drafter
Postby lathanial » Fri Oct 23, 2009 5:24 pm
I was having the same problem. I fixed it by editing the blocks (the .dxf files) and changing the color attribute from layer to block. I normally set colors by layer in AutoCAD but QCad seems a little different.
lathanial[/quote]
lathanial
