QCAD crashes in segmentation faults
Posted: Sat May 16, 2009 1:03 am
I was given a dwg file by a client and used everydwg under wine to convert it to R14 ASCII dxf file. It didn't turn out to be a large file and I cut and pasted the necessary parts of the drawings into a new QCAD dxf file. I then added some layers etc....When print previewing, printing or exporting to PDF the app greys out, then crashes. When going through the kernel log files, I find the logged segmentation faults. I've pasted them below:
May 15 19:10:53 mark-desktop kernel: [ 9337.121325] qcad[13150]: segfault at 0 ip 00000000087e588e sp 00000000fff20100 error 4 in qcad[8048000+f41000]
May 15 19:12:29 mark-desktop kernel: [ 9432.409114] qcad[20050]: segfault at 0 ip 00000000087e588e sp 00000000ffa2a9e0 error 4 in qcad[8048000+f41000]
May 15 19:28:21 mark-desktop kernel: [10384.673113] qcad[20055]: segfault at 0 ip 00000000087535eb sp 00000000ffe6a900 error 6 in qcad[8048000+f41000]
May 15 20:39:59 mark-desktop kernel: [14682.729552] qcad[20493]: segfault at 0 ip 000000000870d3b0 sp 00000000ffa8d510 error 6 in qcad[8048000+f41000]
May 15 20:40:16 mark-desktop kernel: [14699.745231] qcad[22397]: segfault at 0 ip 00000000087e588e sp 00000000ff807660 error 4 in qcad[8048000+f41000]
May 15 20:40:44 mark-desktop kernel: [14728.355996] qcad[22400]: segfault at 0 ip 00000000087e588e sp 00000000ffa830e0 error 4 in qcad[8048000+f41000]
May 15 20:41:29 mark-desktop kernel: [14773.034270] qcad[22402]: segfault at 0 ip 00000000087e588e sp 00000000ffc4d2a0 error 4 in qcad[8048000+f41000]
May 15 20:41:50 mark-desktop kernel: [14793.823893] qcad[22404]: segfault at 0 ip 00000000087e588e sp 00000000ffd803d0 error 4 in qcad[8048000+f41000]
May 15 20:42:35 mark-desktop kernel: [14838.807468] qcad[22410]: segfault at 0 ip 00000000087e588e sp 00000000ffa29880 error 4 in qcad[8048000+f41000]
May 15 20:44:39 mark-desktop kernel: [14962.862364] qcad[22414]: segfault at 0 ip 00000000087e588e sp 00000000ffdc83d0 error 4 in qcad[8048000+f41000]
May 15 20:47:41 mark-desktop kernel: [15144.918426] qcad[22513]: segfault at 0 ip 00000000087e588e sp 00000000ffc67270 error 4 in qcad[8048000+f41000]
May 15 20:48:12 mark-desktop kernel: [15175.743795] qcad[22515]: segfault at 0 ip 00000000087e588e sp 00000000ffd63bc0 error 4 in qcad[8048000+f41000]
May 15 20:50:36 mark-desktop kernel: [15319.508658] qcad[22517]: segfault at 0 ip 00000000087e588e sp 00000000ffb699c0 error 4 in qcad[8048000+f41000]
I'm running QCAD version 2.2.2.0 professional on ubuntu 9.04 x86_64 bit with the 2.6.28-11-generic kernel. I watched what my machine did in Htop when attempting to convert to PDF and the memory is barely used. I'm using an AMD phenom quad-core and I watch no 2 cpu hit 107%, but the other cpus don't seem to kick in - the app just then crashes. I have 4gb of RAM and that barely hits 1gb of use during the attempts. QCAD will happily convert the file to a jpg, but not pdf. I haven't tried using a different dxf version such as 2000 ASCII, but will. I will also try to repeat the problem on a 32 bit ubuntu machine running version 8.10. However, from looking at the logs, is there enough info to tell whether there's a bug in the app, or in my kernel, or just an inherent risk in using everydwg under wine to convert a dwg to dxf? this is the first time this has happened to my machine and I use QCAD every day - my suspicion is the file itself and/or the way it's been converted.
