I explain my problem:
1 - Export to SVG drawing A4
2 - Insert the SVG file in Inkscape or Scribus and the drawing is very small and thicknesses are huge.
If I open the SVG file with a text editor to see the size of the drawing is 22mm x 17mm:
- Code: Select all
<?xml version="1.0" standalone="yes"?>
<svg width="22mm" height="17mm" viewBox="0 0 22 17" version="1.1"
xmlns="http://www.w3.org/2000/svg" style="stroke-linecap:round">
I'm using Qcad proffesional 2.2.2.0
Greetings,
