Fedora update problem
Postby jimbean » Tue Jul 21, 2009 3:27 am
QCAD works fine for me on Fedora 10. After installing Fedora 11 I copy my /home to the new release including the qcad directory. Now the qcad executable is flagged as a bad file. I am running on a 64 bit system.
Is the executable somehow locked to Fedora 10?
If I download again directly to Fedore 11 will this fix the problem?
Jim Bean
jimbean
Postby jimbean » Tue Jul 21, 2009 8:39 pm
Thanks to musicmaker the answer is to install the x86 compatibility libraries. I must have installed them on Fedora 10 and forgot I did it or they came with Fedora 10.
Jim Bean
jimbean
cron
