Hi Andrew, sorry for not being precise enough. It looks to me as if it's a resolution problem. In the drawing I have, I notice that with the pdf export function I get really jagged edges on round corners of text in my drawing ( normal text and text of dimensions ). Text is black in the drawing and the dimensions are grey, nothing going wrong there. I can email you both the different outputs if you like so you can compare, If you need any more info, let me know ( or if I'm not precise enough again...
