"Add block" from Block menu not working?
Postby musicmaker » Thu Oct 08, 2009 5:01 pm
If I select some entities and pick the "Add block" toolbar button, I get asked for a reference point, and I get my block with all the entities in it -- no problem there.
If I select some entities, then use "Add block" from the Block menu, I don't get asked for a reference point, I just get a new block with nothing in it. Is there something else I need to do?
Judy Hawkins
musicmaker
Postby andrew » Thu Oct 08, 2009 5:04 pm
These are two different tools.
- Create block
Creates a new block from existing, selected entities.
- Add block
Adds a new, empty block. You need to edit the block to add entities to it.
