Wish list item
Posted: Mon Nov 17, 2008 8:03 pm
by barjac
When using typed dimensions (as in parallel lines etc.) it often happens that the same dimensions are needed over and over in a drawing, but not one after the other. It would be handy to have a recently used drop down list available on the dimension box in addition to the "last entry" memory as it is now. It would speed up work and also eliminate typos when entering long numbers.
By the way I cannot praise QCad Pro enough !
