QCAD scripting
- Full Member
QCAD scripting
QCAD script
A script is required to implement this function. QCAD can accept the dxf file path transmitted by an external program, then open the dxf, select the text entity in the dxf, perform the explosion operation, and save the dxf file.
Also, is there any information about the script that I can refer to? thks
- VeryCapture_202310191552421.jpg (71.56 KiB) Viewed 6646 times
Re: QCAD scripting
If you want to explode all text entities in the file (or there is only a single text entity), you can use the QCAD command line tool dwgexplode:
https://qcad.org/en/qcad-command-line-tools#dwgexplode
- Full Member
Re: QCAD scripting
Thank you, I will try this method and will reply with the results later.
- Full Member
Re: QCAD scripting
I tried this method but got this errorandrew wrote: ↑Fri Oct 20, 2023 8:14 amIf you want to explode all text entities in the file (or there is only a single text entity), you can use the QCAD command line tool dwgexplode:
- VeryCapture_20231020155315.jpg (85.67 KiB) Viewed 6635 times
- Full Member
Re: QCAD scripting
The above answer is that I made a mistake, and I have been able to successfully execute the explode function. But there is still a question. I need to execute the explode operation on all text entities, while other entities remain unchanged. How should I do this?andrew wrote: ↑Fri Oct 20, 2023 8:14 amIf you want to explode all text entities in the file (or there is only a single text entity), you can use the QCAD command line tool dwgexplode:
Re: QCAD scripting
As explained, dwgexplode explodes everything but ...
You should then include a list of all entity types not to explode.
Type names to omit can be sourced from this list:
https://github.com/qcad/qcad/blob/maste ... y.js#L1349
- Full Member
Re: QCAD scripting
Was looking for it, see edited post above.
Remark that not all are visible things. e.g: a layer, a block (but a block reference might), ...
And that not everything can be exploded. e.g.: a lineType, an arc, ...
Re: QCAD scripting
dwgexplode is geared towards exploding everything.
You'd have to provide a list of all entity types that are acceptable (i.e. don't need to be exploded):
Note the quotes for the -t argument.
dwg2csv can list all entity type names:
dwgexplode.bat -t "Block Reference,Dimension,Aligned Dimension,Angular Dimension,Angular Dimension (2 Line),Angular Dimension (3 Point),Arc Dimension,Diametric Dimension,Ordinate Dimension,Rotated Dimension,Radial Dimension,Ellipse,Hatch,Leader,Tolerance,Polyline,Solid,Trace,Face,Spline" -o d:\explode.dxf D:\testfiles\New2.dxf
dwg2csv.bat -l
- Full Member
Re: QCAD scripting
Thank you very much, this answer is very important to me, I will follow this method to experimentandrew wrote: ↑Fri Oct 20, 2023 9:55 amdwgexplode is geared towards exploding everything.
Note the quotes for the -t argument.Code: Select all
dwg2csv.bat -l
