command and options
shanejenner
command and options
Postby shanejenner » Tue Nov 24, 2009 4:44 pm
Hi options tool bar dosen't appear and can not activate at the top of page i have layer list tabs which i would like to remove It looks like i should be in command mode but can not seem to activate. system. Mac os Q CAD PRO
Shane[/b]
Postby andrew » Tue Nov 24, 2009 5:27 pm
Show / hide options toolbar:
Menu: View - Toolbars - Tool Options
Note that the tool option toolbar is empty when you start up QCAD and will show options whenever certain tools are active (e.g. draw - line - parallel to enter the parallel distance)
Postby andrew » Wed Nov 25, 2009 9:13 am
You might want to reset QCAD to its default configuration. See:
http://www.ribbonsoft.com/qcad_doc_faq.html#7
If you don't know how to delete system files under Mac OS X:
- Quit QCAD
- Start application "Terminal"
- Enter this exact command:
rm ~/.config/RibbonSoft/*.ini
- Press the Enter key
- Start QCAD again
Return to “Chat”
